Re: a recall for E60?
This is from Australia:
Rear shock absorbers
Date: 11/07/2006
Supplier Name: BMW Australia Ltd
Product Make: BMW
Product Model: E60, 61, 63, 64, 65, 66 (BMW 5, 6, 7 Series variants)
Target Number:
Model Years From: 09.01.2006 to 26.04.2006
Consequences:
Campaign Number:
VIN Range:
Serial Range:
Product Info: BMW Vehicle - E60, E61, E63, E64, E65, E66 - Production range 09.01.2006 to 26.04.2006
Defect Details: The lower rubber mounts may come loose from the rear shock absorbers. If this occurs , wheel guidance would be lost and, depending on the driving situation, it may no longer be possible to control the vehicle safely.
Consumer action: The rear shock aborbers should be replaced. Contact your preferred Authorised BMW Dealer as soon as possible. For further information and guidance call your preferred BMW Dealer or BMW Group Australia on 1800 813 299.
Market Coverage: National
Recall Coverage: National
This one is from a UK website:
Vehicle Recall Details
Reference : R/2005/022
Manufacturer Ref :
Make: BMW
Model : E46,E53,E60,E61,E65,SERIES3,5,7 AND X5
Launch Date : 2/8/2005
Numbers Involved : 697
Build Start Date : 11/30/2004
Build End Date : 1/31/2005
Details
Concern : THE BEARINGS OF THE FUEL INJECTION PUMP MAY FAIL
Description : The bearings of the high pressure fuel injector pump may fail after a short travelled distance (approximately 3000 to 6000 miles) This leads to a total failure of the engine's fuel supply, which results in the engine stalling.
Remedial Action : Recall likely to be affected vehicles and replace the fuel injector pump.
