a change in cable to a great change in speed
darrenteo
HI Bro,
I have come across in overseas a cable that to be replace by your current one at the accelerator area. It will help to respond faster when u step on the accelerator. Anyone interesed?
I have a friend here and he try on his 520i and was told that the response was good.
Re: a change in cable to a great change in speed
darrenteo;326463 said:
HI Bro,
sounds like the sprintbooster
if it's to be replaced by the current one.... then .. wait..nvm..
different from sprint booster?
i think this cable is called sprint booster
Alot of ppl here using them already. Singapore got sell.
Its called "Sprint Booster".
Search and u can get more info on it.
It's sprintbooster for sure. Perhaps other brands have developed similar products too?
Basically, it's a device that reduces the physical pedal travel distance and electronically translating it to a certain multiplication of actual travel distance. Hence your ride will feel fast but in fact it is only you stepping harder on the pedal. So don't expect better hp figures. your 0-60ft may be quicker by a wee bit though.
Was contemplating to having it installed in my 6er but find that my SMG already sensitive enough. Hope this helps.
Sure sounds like the sprintbooster to me.
But no replacement of cables needed leh.
buy and put one.
as backup device in case the "no cable" breaks?
no. then you can use as whip.
remember to get some cable tie as well
