6 Car Maintenance Tips to Prolong Your Car’s Lifespan
Infratint Automotive Film
Trusted Sponsor
No matter how much you like something to stay permanently, it is a known fact that everything is just temporary. Yep, even that fancy car you just bought will not last perpetually. However, there is something you can do that will, for sure, make it will make your car’s lifespan longer than it should be. With this, car maintenance plays a vital role in keeping the brand new appearance and extending the life of your four-wheeled vehicle ─ which every vehicle owner must follow. Although car maintenance means allotting a little time and money, it is important to know that depriving your vehicle the proper care and upkeep that it needs will cost you a lot more, which is why the latter should never be an option.
Here are some of the best car care tips that are sure to prolong your car’s life!
1. Be patient during the break-in period
So you just pull your car out of the dealer’s lot? Before you get excited and go on full-speed driving, here’s an important thing to keep in mind: keep your speed under 55 mph (88 kpm) or to the speed which your car manufacturer recommends during the break-in period, especially the first 1,000 miles (1,600 km). It is also a must to only use light to medium acceleration, where the engine RPMs keep below 3,000 for the first few hours of driving.
2. Check the brake system
Regular checking whether your brake system is working efficiently is one step not to avoid getting into an accident. And by not getting into such road mishaps means extending your car’s lifespan. It is important to make checking your brake fluid a habit. Change the brake fluid once it becomes dark, for that means that the fluid is filled with rubber. Also, take note to replace your brake system every two years.
3. Regularly check your tire pressure
Every car has a recommended tire pressure which you can see by referring to your owner’s manual. Remember that checking your tire pressure on a regular basis is not only lets you have comfort when driving but can also make your car’s life last longer.
When checking your car’s tire pressure, you can use a gauge in case your car does not have a tire pressure monitoring system. Also, there are smart devices that can be used which enable you to observe your tire pressure via your mobile device.
4. Check the engine coolant level
Given that heat is generated whenever your car moves, it is essential not to disregard checking the engine coolant level as the hoses used in transporting the coolant level can become susceptible to being damaged if they carry high-pressure fluids. Good thing, cars these days come with a translucent coolant reservoir which allows you to determine the coolant level without opening the reservoir lid.
5. Wipe down your windshield, replace the wipers
Dirt can build up on the windshield and when it is not cleaned off, your visibility while driving will be reduced ─ which sometimes leads to an accident. In order to prevent road misfortunes and to spare your car’s glass from deterioration, wiping down your windshield and replacing the wiper is necessary.
6. Install an automotive window film
Since you spend a lot of time inside the car, it is reasonable enough to maintain your car’s interior. How? Installing an automotive window film in Singapore is one great solution to prevent the interior of your vehicle from being damaged, provided that it gives an ultimate car UV protection. Not only does it protects your car’s interior from the damaging rays of the sun but it also lets you have comfort when driving considering that automotive film helps block heat and cuts off glare entering through car’s windows.
Should you need quotations about car window tinting in Singapore, you may contact Infratint through our customer care hotline 6684 5330 or 9456 0888.
