T Taeyoon Member Dec 15, 2018 #1 Hi Guys, Im intending to buy preowned 520i 2014 facelift model. Mileage 70k. 2 owners. wat should i look for? Appreciate ur advice.
C clemgoh Well-Known Member Dec 15, 2018 #2 Mainly Oil leaks - valve cover, oil filter, sump causing oil loss Transmission smoothness. Any regular change around 50,000km, if so you will be ok. Turbo charge pipe cracks, turbo waste gas rattle Front Control arm worn out. Ask Codewerx
C clemgoh Well-Known Member Dec 15, 2018 #3 You may need to check Pcv and do a walnut blasting as you have a direct injection engine. Youtube it
