5 speed to 6 speed
hitmee
anyone know the cost of upgrading steptronic 5 speed to 6 speed? is E90 using the 6 speed steptronic? can it fit into E46?
Re: 5 speed to 6 speed
Anything is possible. It depends on how much money you wanna spend...
It's no direct swap for sure. Software, hardware all different... The cost of the custom software and hardware to make the gearbox fit into an E46 will probably be twice the price of the gearbox itself...
Pfitzner Performance Gearbox
Can't find the site on Hollinger.
You wouldn't be interested in both of these gearboxes. They compromise comfort for performance and is able to handle high hp application. They use Straight Cut compared to the conventional Helical cut on the teeth and it makes a whining sound that my cause irritable bowel syndrome. :D
dun be mad..its a lot to do....n u r better off buying a new car...
Yup, Toto is right. Dun be siao la. And worst of all, why would you want to spend so many thousands of dollars on something that does nothing to your car?
Steptronic to another Steptronic??
No increase in performance nor comfort. MAybe a slim mini little bit..thats it. unless...its a merc stepronic..ah HA!!
htimee just buy BlackS's car. Worth it!!
/start OT
hitmee, i was the guy crossing the road and staring at you at the taka/mandarin hotel junction.
hahaha. recognise your rims.
/end OT
RaptureM3;166772 said:
/start OT
/end OT
oh, no wonder i thought who is it keep staring at me. hee hee for a moment i thought i so good looking. ha
are you the gal or the guy? ke ke
aiyo, i thought is a simple switch. didnt know it is so troublesome. oh forget it then.
what about changing gear ratio?
also dont bother, save the moolah..
actually the E46 318 drivetrain is pretty good. The gear ratio is that tall and u have a final drive of 3.91 for a quick pick up but losing out a bit on the top end. It's a good car:)
go n get urself the GB 323, everything u need is in
why dont you consider the all-new lexus 8 speed gearbox? since you're gonna spend all that money and effort, might as well go all the way!
