335i Engine Oil temp on a stock car
topless 8398
Any bro's 335 still stock,what's your oil temp?
Or can remember before install piggy back?
Thanks in advance.
Re: 335i Engine Oil temp on a stock car
Thanks in advance.
yours overheated??? too high boosted?
Stock already high. 120 if I rem correctly
normal driving on sunny day 115degrees,NSHighway 260km/h at 125degrees.
Not happy unless can compare with stock car,I got smic x2,can never overheat unless go track.
Thanks for your info,my smic do help 5degrees on normal driving and 10 degrees+ on wot.
Mine N55 is running 120 if long run and smelly smelly also 115
Stock ride after spirited driving is 120 degrees and plus for sure, assuming you really gun the car...... normal driving should be 100-110 range.
Friend's stock N54 110-125
For my N54, mods as listed in signature below, currently running BASSO Ceramic engine oil 5W30
Normal driving 90-95, aggressive driving 100 -105 max on JB4 map 2 or 5.
Temps measured by Defi gauge
Previously while on Mobil 1 my oil temps were 100 cruising and 110-120 aggressive driving.
What engine oil are you running and rating ?
If i remember correctly my stock car at least 115 after 20mins normal drive,never obtain 100-110??
All depend on how each drives.....
Yours sama sama compare mine,have u ever hit 120+ with WOT,yours stock?
I believe yours must be choon cos u using defi gauge but can u tell me your reading at your car oil temp bcos i aint got defi:p
Maybe our 335 oil temp not accurate.
mabe mine not choon... as i just gotten my ride not long and yet to WOT. Mine is the Performance option kit 1. Not consider tune up as JB type. I am going for stage 2 soon and i try to compare once the kit arrives....
ok will observe the dash meter temp gauge.
i think Defi uses actual sensor while the meter gauge is from OBDII readings ?
i hv both defi and boost gauges on the dash, i think both v essential for our car leh.
2 gauges still ok, if got 5 then v ah beng looking
May i know where u install the defi?Thankyou very much:)
I think I am the only one who did this Mickey Mouse thingy.......
this is nice. will it trigger off any check light? where you got it installed? thanks
][/quote]
i saw this too but it fits only the 53mm gauges whereas mine is 60mm
My install was done by Garage R (out of convenience than preference) .....
Kenn,
what was your max boost on stock turbos ? 1 or 1.2 bar ?
