335Ci?? Twin Turbo??
morphisis
Hi guys, i saw in a magazine about the 335i or is it 335Ci... comes with twin turbo and stock is at 305bhp???
is it here in Singapore already?
Re: 335Ci?? Twin Turbo??
Bro you damn blur man. not out yet lah
its really 305bhp??? really twin turbo??
yes!! yes bro... there is a folder abt the coupe thingy, search it...
my take is that dont buy the first batch , think should have bugs problems. plus the prices would be sky high
well depends... hehehe if pml decided if the 335ci's are on indent basis... they will keep the price niche and it won't come down even though it is 3rd of 4th batch. as for bugs agree but by the time the 335ci hit the island there will be quite a number of them running around in EU and North America.
oct 21 pml launching 325ci (no 330ci) no news on 335ci as yet.!?
Hi fellow frens:) and forumers:) , u may wish 2 the follwing URL on a write-up in the Business Times published on 29 Jul 2006: http://business-times.asiaone.com/sub/motor/story/0,4574,203479,00.html?
For ur easy reference, some key data:
BMW 335i Coupe
Engine: 2,996 cc inline-6 twin turbo
Gearbox: 6-speed automatic transmission
Max power: :drool: 306 hp @ 5,800 rpm
Max torque: 400 Nm @ 1,300-5,000 rpm
0-100 kmh: 5.5 secs
Top speed: 250 kmh
Full review from Autoweek - conclusion? Damm bloody GOOD. :)
http://autoweek.com/apps/pbcs.dll/article?AID=/20060731/FREE/60719007/1008/FREE
There are two sides to this story. First, there is a coupe version of the latest 3 Series, arriving predictably after the sedan as the latest in a multi-sequel movie franchise. Then there is the subplot: The range-topping 335i coupe is the first BMW with a turbocharged engine in 20 years.
Of the two aspects to this story, BMW’s return to forced induction is probably the headline. Having pioneered street-car turbocharging with the 1974 2002 turbo sedan, BMW gave up on it after the deeply unloved flagship 745i was dropped in 1986. Fitted with a turbo version of the company’s 3.2-liter straight-six, the 745i was infamous for laggy power delivery and excessive thirst. Since then BMW hasn’t been above dropping sniffy comments about those of its rivals who have resorted to forced induction to increase performance, so the 335i is a car with plenty to prove.
From a design standpoint, the 3 Series coupe looks pretty much as you would expect. The previous two generations of the drei coupe sold by the boatload, so BMW has wisely opted not to frighten the horses with anything too radical. That means a slightly wider stance than the sedan and similar front end styling—though if you look hard, you’ll see the hood, headlamps and front fenders are unique to the coupe and the windshield angle is shallower. Xenon lights with BMW’s “Corona light rings” are standard.
The roofline is lower than that of the sedan but higher than the previous-generation car, and the coupe is pretty much spared the “negative shape” Bangle-era design language, though a close look reveals some slightly concave surfaces lingering at the bottom of the door. The fat taillights look more Lexus than BMW.
Move inside the cabin and the coupe is immediately familiar to anyone who has crossed the threshold of its sedan sibling. The dashboard is identical, sharing common switch-gear and the same fiddly controls for the heating and ventilation system. Though the basic car does without, the debatable joys of iDrive will be an option in conjunction with satellite navigation.
Front seat occupants enjoy plenty of space, and there is a range of driving position adjustment to suit most any size pilot. The rear seat area is surprisingly spacious, too; access to the back is a little awkward, but anyone sent back there will enjoy reasonable legroom and headroom. The engineering team admits to looking at the spacious Mazda RX-8, and it shows. Neat details include Mercedes SL-style seatbelt “feeder arms” to silently hand you your harness when the ignition gets switched on.
At this point, anticipation has built to such an extent that actually starting the engine (now by dashboard button rather than an old-fashioned twist of the key) is anticlimactic. The powerplant is eerily quiet at low revs, devoid of the bristly soundtrack you would expect from a BMW inline-six. Even blipping the throttle doesn’t do much for the aural accompaniment, the turbochargers conspiring to stifle the induction and exhaust note.
That’s right, turbochargers—plural. The 335i goes into the world with not one but two compact turbines. The low-inertia turbos work in parallel, each supplying compressed air to three cylinders, and are designed to eliminate turbo lag. In conjunction with gasoline direct injection, the net result is 300 hp at a relatively low 5800 rpm, accompanied by 300 lb-ft of torque all the way from 1400 to 5000 rpm.
On the move, the flat torque plateau quickly proves itself the 335i’s defining characteristic. It does not feel particularly quick off the mark, but the engine’s smooth manners shine through as it gathers momentum. Turn up the pace, and the engine responds in good humor, feeling more than capable of matching or beating BMW’s official 0-to-60-mph time of 5.3 seconds with a manual, or 5.5 seconds with the smooth six-speed Steptronic auto (that’s not much off the 4.8-second 0-to-62-mph time of the Euro-spec M3). The 335i enjoys more mid-range torque than its M-badged sister, and on the tight roads of the Austrian test route it proved phenomenal at passing slower traffic.
Even knowing the engine is turbocharged, it’s near impossible to discern any hints. Turbo lag is not an issue, the motor pulls cleanly with as little as 1200 rpm showing, and throttle response feels instantaneous throughout the rev range.
And you’ll search in vain for any aural clues: The 335i does without the water-rushing induction noise that tends to go with turbocharging, let alone uttering anything as crude as wastegate chatter. The only real giveaway is the engine’s slight breathlessness at higher revs; there is little point in going beyond the 5800-rpm power peak. Toward the top of the rev range, the engine’s natural soundtrack improves and some well-muted six-cylinder yowl enters the cabin. It is an engine we will become familiar with as it spreads throughout the lineup, starting with the new X5 later in the year.
Dynamically, the 335i is far from being the junior M3 many people expect. It’s a sporty enough proposition for pretty much all of its core audience, but it’s clear from the start the chassis is set up with comfort as the priority. On the generally smooth tarmac of our test route in the Austrian Alps, the coupe wafted over everything the topography could throw at it—Michigan in the winter will be more of a challenge, but on first impressions it feels like a car that will keep its composure pretty much regardless.
Spring and damper rates are firmed up a bit from those of the sedan, but handling is pretty similar: strong resistance to roll, excellent grip, and a neutral, adjustable balance. BMW claims opting for a turbocharged six-cylinder instead of a similar-output V8 saves 140 pounds in front end weight, sharpening those already glinting responses even more.
Okay, we do have one complaint. The 335i is being sent out into the world with no limited-slip differential, which doesn’t really seem in keeping with the whole 300-hp-and-rear-drive thing. De-energizing the stability control for sport is largely an exercise in futility, as under hard cornering the unloaded inside rear wheel starts to spin and smoke as that sizeable torque peak arrives. And on a related note, BMW is making xDrive four-wheel drive available as an option only on the entry-level 328i coupe; 335i owners will have to battle for winter traction.
The 335i’s talents are so well-rounded as to make it pretty much spherical. It’s good-looking, great to drive, surprisingly practical and blessed with a superb powertrain. Now the really interesting question: How much faster and firmer will next year’s V8-powered M3 be?
this is the line of the year... award winning.
Just go to the overseas sites, like e90post.com
Lotsa info there n pictures of the 335i Coupe and also the new 328/335 4-door sedans. Do your research on these sites and be a smart buyer when the car land on our shores.
Oh BTW that car is really cheap in the USA....hoii...Parallel Importers are you listening or koon-ing?
A lot of magazine and review always mention that BMW turbo charging stops 20 years ago but they failed to mentioned that it's actually for petrol engine....
The 320Cd and the 330Cd is well and alive man....
335 335 335 335 335 335 335 335 335 335 .........
buy 4D...... 3353 or 3335 or 3533 or 5333 or 0335 or 3350 ......
yeap yeap... only for petrol.. the desiels have been running around!!!...
SM.. you just got ur car.. no no no.. dun scratch ..
Doctor Yuen, are you chraging all yr luvly patients $335 per consultation today? :)
haha my friend.... i think if I do that i will be called up for overcharging!!!
cannot lah.... must have ethics you know..
I just read the official review by autocar... it really sounds darn good man... the universal verdict is the immense driveability of the car - 400NM of torque from 1,200 rpm.... thats AWESOME!!!
drool drool....
but i dont like the stock look.... looks very "tut"... the rims are hopelessly ugly... it needs a bodykit, 19s rims, and lower height... other than that, wonderful package man..
The hot topic now should be how much PML will price the car..
the power bulge like m3 leh...anyhow, those are some MFing big big big brakes..!!! if tyre punctures just throw off the wheels and continue running on the brakes...they seem to be almost the same size...yikes
drool drool....
Still lower? But the side profile already looked very low leh Dockie. I agree though that this car deserves 19" rims. What would be a nice and suitable rim for this handsome drive? :confused:
