335 vs GTR vs Supra Engine Talk
Re: 335 vs GTR vs Supra Engine Talk
Stronger block material is used to counter the side loading of pistons and prevent so-called cylinder walk. Think it's one of the factors affecting BMEP but rod ratio would be another factor also. The ratio of rod length to stroke is indicative of side loading of the piston in the bore which affects power. Shouldn't iron sleeved aluminium block be better in perfomace if good coolant passage design could reduce the differences in the thermal expansion coefficients between the 2 materials?
Good work, guys. Credible responses from some well informed people in this forum.
And thanks louis, for the article on Wards 10 best engines for 2002.
It turns out that both examples of iron block engines that I picked out earlier got a mention that year.
2002 looked like a vintage year for good engines. In addition to the 2 previous examples, there was also the Porsche Boxster's 2.7, the Nissan 350Z's 3.5 and the Honda Integra's 2.0. All excellent performers in their respective classes.
PerverTT;309667 said:
Shaun - Is this the reason for the use of an iron block in relatively modern engines like the ones used in the E46 M3 and in the VAG 1.8T? The former is designed to run at high revs while the latter is often subject to insane boost pressures. Had always thought of iron as a low cost, low tech material for use in an engine block.
The use of cast iron is just to keep costs low I believe. It's cheap and strong, but heavy.
To have an aluminium block as strong as, or stronger than, a cast iron one requires either lots of time spent designing it .. lots of FEA and tests...iterative evolution, etc. and good alloys, giving the result of high strength and rigidity per pound (F1 and other big money manufacturers' route), or a block with fairly large external displacement from being beefy everywhere, overbuilt, and not as light as it could be but still somewhat lighter than cast iron (route just about everyone else takes).
Even then there are very few apple to apple comparisons of cast iron to aluminium blocks. In the american V8 markets there are some extremely high quality aluminium versions of cast iron stuff, but they're never make as much power as cast iron. Typically 10-25 hp down on a 700-900hp engine. The thing is the aluminium stuff isn't built specifically to be as strong though since the block itself is 50-65% of cast iron weight, leaving you with lighter, better handling / accelerating vehicle.. which goes further in the direction of the goal which is winning races, not making the most power.
To some degree I don't think you can actually build an aluminium block using traditional alloys used so far, to do what iron does, because of aluminium properties.. is just ends having to be real thick everywhere assuming you absolutely match strength and rigidity. The thickness is not really a concern in most places except cylinder walls where you would end up with larger temp gradients covering a larger distance in the thicker walls. The greater expansion and contraction can't be easy to deal with in a long service life engine. There have been some solid alu billet blocks just about devoid of water jackets, but those are ultra short duration drag race only and still rarely used. Memory on F1 tech regs is fuzzy, but I think they have some degree of freedom to use non typical alu alloys up till a point. Their engines are extremely light for what they do, but also so finely engineered and replaced relatively often. Even if they were forced to use traditional alloys, I'm sure they live with the tradeoffs in strength and stiffness because light weight is such a big factor in laptimes. Of course they try to absolutely minimize tradeoff by perfecting it within their given engine weight limit.
In production cars, move away from cast iron is mainly due to wanting to keep weight noses light so all else equal, car doesn't handle like a pig. They're never chasing outright power from a given external displacement, so alu is perfect. Also to save overall weight so they can put more gadgets in the car.
Re: BMEP.. there are currently a few racing classes where NA gasoline engines that make close to and IIRC even exceed F1 BMEPs at peak power. Of course F1 is running those BMEPs at stratospheric engine speeds so it is a feat in itself. There also have been engines in the past used in similar applications (F3000 , high speed formula cars) that ran 17 bar BMEPs at peak power.. which is some sort of NA gasoline record. It was a result of rev restriction rule and the forcing of making more power through charging efficiency.
Faster.. wow rod ratio.. that argument can cover pages and pages.. so given that I can't even cover enough on that topic to really do justice to a reply.. I will provide short summary.. forgiveness please. In this realm, especially in beefy blocks, it really does not matter despite what you've read in just about all the mags, hear the "gurus" mention. Ratios of 1.5 have been run very successfully in 24 hour races. Further when you take apart a a high mileage high stress engines of supposedly bad rod ratios, you still wind the bores clean up in a few thou, all except near the top where ring friction at breakover digs into the walls over time. You just never really want to give up displacement, where not regulated, to reach a rod ratio - unless your starting rod ratio is plain ridiculous.. like 1.2 and lower (not fixed) if that's even possible before running into other issues.. because once you factor the displacement and normalize for flow, your peak loads everywhere except on the thrust axis are lower, and the fact that is it higher still doesn't factor in the average block, much less cast iron stuff. The range where you actually have to start really calculating tradeoff is just never seen in the real world. When you gain displacement at the expense of rod ratio in the usual ranges, you see BSFC improve. Which shows overall efficiency gain despite greater thrust forces. And if those thrust forces aren't damaging anything over a long period, what else is there to worry about?
F1 has traditionally been at 2.6-2.9, but that's due to packaging limits of the airbox. As you cut down the decks on the V to reach lower more sane rod ratios, you reduce space available for an efficient inlet tract. The engineers have mentioned they would like to cut down the decks, save on block weight and rod weight, get rod ratios to much lower values, if it didn't end up with overall compromise on power because of the stacks on opposite banks getting too close together and the shape of the airbox with no space between the V. Again all tradeoffs.
Re: liners.... they are interference fit with a minimum of what will hold after block is up to operating temp (usually .002-.003 on a ~4" bore at room temp, depending on alloy). Liners helps somewhat with more evenly loading the aluminium behind it, but in the end if the base material is moving, nothing will help, so the base structure being strong and stiff is always better. I believe there have been some aluminium blocks run linerless with only a coating directly applied to the bores. Expensive stuff with specific design and very homogeneous castings to work.
Hot honing deals with the issue of cylindricity at operating temps. At room temps the bores are all distorted which is fine. F1 engines can't turn over without preheat, for this reason. Neither can any pure race engine, safely, without preheat. Clearances in general, including mains are also tiny, about 1/3-1/5 vs even other very high performance stuff.
Well yes, since practically all components are related and it's a never ending quest to find more power without too much tradeoffs yet maintaining drivability. However, it was not in my intention to drift away, so please forgive too.
My understanding of rod ratios was that it mainly deals with dwell time. And like you'd mentioned, I also do not see how anything outside of 1.6 - 1.8 is ever going to be practical on the street or maybe I just havn't seen the manufacturerers do it much. On the subject of displacement gain, Honda had a B17A for awhile, I think that was a good example of having a somewhat less ideal rod-ratio and having a larger displacement at the same time. This was the only example I knew, so again I could be wrong, but the B16B really proved otherwise. Thanks again for your explainations.
ps- I had noticed a trend among explicitly knowledegable gurus such as yourself to use the terms tolerance, clearance and interference alot.
Yes it does affect dwell but these days with such good heads straight out of the factory there is no requirement to dwell around TDC to reduce the suddeness with which the cylinder draws on the head. It used to be an issue when heads (esp 2V) were poor flowing, but not anymore. Also burn characteristics and knock resistance, but again these are all minute. When you're chasing reliable efficient power the overwhelming thing is reducing engine speed required to reach it.
Honda has produced a few 1.5 and 1.4 range stuff I believe. Yes stock engines most often fall between 1.6 and 1.8, but remember they have no real restrictions and are never pressed to make the most power out of a given block. When you start to look at arenas where they do have restrictions and are trying to maximize power out of a block, they within extremely broad windows never ever give up displacement to reach a rod ratio. Most often they reach other limits like cylinder length of crankcase clearance before running outside of this broad window.
In the performance world there are very few hold outs on the rod ratio issue left to the point it is almost unanimous. You design the piston for the task, put as much stroke as practical in it, and the remaining distance is made up by the rod. There's no magic to it. Just a month ago I spoke to one of the last hold outs who is using it as selling point magic for his business, but when asked directly whether he would trade displacement to reach this supposed ideal rod ratio, he straight out said no. Yet he's being quoted all over the forums and magazines the wrong way. Or he on purpose hasn't explained it to them to clarify.
Every engine failure I have personally seen has never been thrust related. I don't recall ever having read of any failure in the last 10 years related to thrust, but I've read of many due to other reasons. I've never seen photos of great wear pockets or any cracks in the portion of the cylinder where max angularity occurs (which is right in the middle of unsupported part of cylinder, usually halfway down the bore) and this supposed great thrust is applied. If you have any info on failures like that I'd like to see.
Remember also that by the time max angularity occurs, peak pressure is over by about 70 crank angle degrees. If you look at NA pressure decay, pressure is down to around 10% or less, of peak. Force inducted engines are a little different but still down at around 25% or so of peak, in raw value the 25% number is still 3X higher than NA's 10%. FI engines are also much less dependent on engine speed in order to make power. Then there's inertia thrust alone even if you take away all combustion pressure, but this is usually smaller at 0.25 to 0.75 that of pressure thrust, even in high speed sub 5 digit RPM engines, depending on whether NA or FI.
Obviously if you're running FI on a weak NA designed aluminium block with an open deck you try and hold in place with inserts or posts, large unsupported cylinder lengths, etc. then yah you have to think a little harder, but this already is into the realm of squirelly backyard stuff that one would hope never to come near.
With any proper engine, esp NA or cast iron of beefy alumnium ones, there is no use worrying about rod ratios unless you're pushing an extreme. Even then, if there's been any evidence with that specific extreme of wear or failure from thrust forces, only then is there cause for pause. And as overall indicator of efficiency you can always look at BSFC. If it gets worse then the engine is working itself apart. It is an easier to track and use indicator in NA vs FI though.
Those are simple machining terms and I guarantee you I am not a guru, just interested in things of this nature.
Shaun - Thanks for the comprehensive explanation on aluminium v cast iron. Given the cost/strength disadvantages of aluminium when compared to iron, I'd say that car manufacturers must be pretty desperate to achieve weight savings when they elect to use aluminium as a block material. Good example - when BMW moved from the iron M50 engine to the aluminium M52 engine. I understand that the reason why iron was kept for the S50 engine series used in the E36 and E46 M3 was because of the stresses the high performance engine was subject to and because the cylinder walls were paper thin. Someone please correct me if I'm wrong.
BMW was one of the few brave engine manufacturers that experimented with liner-less aluminium engines in the early 1990s. They used a hardened nikasil coating inside each cylinder bore. Which was terrific in theory but caused American BMW owners much grief when the nikasil coatings failed, ostensibly because of high sulphur content in their petrol.
Curious to find out what other engine makers used for block material, I googled details of the Honda S2000 engine - a typical Japanese banzai engine if there ever was one. Surprise, surprise, it's an all aluminium affair. No cast iron except for the bearing insets. Even the cylinder liners are made from FRM (fibre reinforced metal).
Perv, re: the E36 and E46 M engines, that is one way of phrasing it which actually means the same thing. It could be done in aluminium, would be lighter, might make a slight bit less power (assuming you mirrored the specs, but no law saying you must - you can always tweak something to make it back up. All else is never equal in production cars), but would yield a better handling car. But again, there are many ways to make a good car car despite an heavy engine up front. At every level you can take one step back and design around a constraint. Constraints are everywhere.
Similarly, the F20C could be made of cast iron, but would hurt the overall vehicle despite probably gaining a small amount of power, which could have been done in any other number of ways (FRM probably one of them!). They could have designed around a cast iron block too, but chose not to. They chose the route we now see, out of a hundred others. Exact reasons are anyone's guess.
Yah that engine is wonderful. Would love to stick one in an Exige. Honda puts out incredible work. The tolerances, finishes, and materials on their production stuff are better than just about all others, to the point that it is closer to race. I wish they'd build a modern mid engined supercar to take on all the Europeans, and Nissan.
According to the official S2000 book, the F20C and it's 2.2L descendant, was special in its revvability because the precision in its manufacture of every part of the engine was an order of magnitude better than anybody else. The tolerances were an order of magnitude smaller, etc. So it was manufacturing prowess which made it great, not only design.
If one sticks a current JDM CTR engine inside the S2000... how will it perform vs the original-engined car on track, hypothetically speaking?
when we talk about this, we gotta talk about potential also...
from what I've read and heard oer kopi - OK the F series engine is quite bespoke.... and maxxed out. no matter WTF you do with the engine, short of FI, the power appreciation is so small compared to K.
On the K, just change ECU and a good intake already can move peak torque down until swee swee ... adding power is very responsive to many techniques, because Honda didn't even screw around with this engine too much, so it is underoptimized.
So ... this is a very intriguing question - how would a maxxed out K20A engine perform inside a S2000?
Not too sure if the K20 could fit into the S2000, think the orientation could be opposite but that would be interesting.
The S2000 F20C is a oversquare bore design and was geared more towards high end power where the K20 is squared and designed to give low end torque with decreased revability and top end power.
F20 was also a derivative from the F2000 racing program. It had probably been maxed out and engineers wanted their flagship model to be special since it was made solely to commemorate Honda's 50th Anniversary.
Quote
The S2000 development project was handled by Honda’s engineers at the Wako and Tochigi, Japan R&D Centers. It was based on Honda’s SSM (Sports Study Model) concept car first shown at the 1995 Tokyo Motor. Honda took three years sorting the car out since it was their first rear-wheel drive car in 33 years. Testing included more than 20,000 miles with prototypes in Europe.
It was designed to commemorate Honda’s 50th anniversary and sheer driving pleasure. The emphasis was on technology and Honda’s racing heritage and it was directed to the ultra enthusiast’s but with goal to combine performance and practicality. Power-Grace-Balance were three targets.
The primary design directive was to make the driver feel “as one” with the vehicle. “Lighter in feel than a Porsche Boxster, more like a Lotus Elise.” Such were the lofty aspirations for Honda’s Executive Chief Engineer Shigeru Uehara. Topping Uehara's list of desired attributes were high performance and first-class driving dynamics.
Yes, lighter in feel to the boxster BUT THE CHASSIS IS TOO SOFT (will be trashy over bumps, cannot make suspension too hard because the softness will be more obvious) and the engine no enough bottom end!!! in isolation is is GREAT but compared to the box, it lose out a little for sure.
If only there was a hard top version for it. Hard top vs soft top argument never ending but there wasn't any for the Miata also. Other than base pricing, ease of maintenance and ample supply of aftermarket parts would also be consideration for most auto-Xers' & trackkies.
K is an evolution of the F ... its a much more flexible engine which is important for streets. Mod gains are also very attractive for the K ...
the K shd bolt right up .. even the gearbox mates well. but i dun think any S2K owner will ever take this "philosophically backward" step
in any case .. both engines makes enuff powar .. juz gotta practise more and refine the driving to get the most outta the chassis
Which chassis is too soft? How stiff is the boxster? Which open tops are stiffer than the S2000?
Isn't an Elise or Exige down at around roughly 10,000 Nm / deg?
Today, 12:10 PM
This message has been deleted by powersteer.
Eh Kelvin, don't be shy !
fasterthanferrari;310712 said:
Honda R&D Co Ltd permitted their engineers to write an engineering paper about the S2000's F20C four-cylinder, one published by the Society of Automotive Engineers.Very detailed comparison of the F20c and H22, it's clear that the F20C is based on H22 and what they strived to improve on.
Development of the High-Power, Low-Emission Engine for the "Honda S2000"
Just looked through my archives... I have a different paper by Honda with almost exactly the same name, cept it was presented in '99 at a different conference, and the comparison is to the F20B, not H22. If one of the admin will bump the .zip or .pdf attachment limit to 700 kb, I can attach it for anyone who is interested. Yousendit is a drag.
Nm/degree is a misleading metric. for example, for a long wheelbase, 1 degree of twist can result in a larger deflection at the suspension mount point.
deflection = 2WB^2 - 2WB^2 cosine (angle of deflection)
where WB=wheelbase
So sometimes, depending on the wheelbase, you will feel how soft a chassis is even though the torsional rigidity is very tough. In addition you have those bushings and the rigidity of the suspension mounts to contend with.
aiya you just drive a box and a S2K back to back and tell me which is stiffer. For me it's very obvious that the box is noticeably stiffer.
i've tried searching, but i can't seem to find figures for the S2000... anyone knows?
