316 engine wih manual gearbox cheap.
21dec1983
316 e36 engine with manual gearbox with ecu and hardness. selling cheap $800 . kept for spare for some time so selling off. sms me at 82889488 . pls dun pm here. seldom log on. thanks
Re: 316 engine wih manual gearbox cheap.
Cheap way to go Green n save fuel. Bump for your sale.
swt, sure can. Go for it n get the short shift kit. u will love it.
any idea how much would installation cost and also how long? thanks JT!
Jaws will know better. Jaws, where r u, swt going for manual convertion
just called m and q mr chia, he said installation cost is $1k but he said the gearbox must come with other stuff needed for the conversion....will pm the seller separately...
You can follow C3P0 n go to JB for installation. I don't think the workmanship will cost you RM$2300. maybe RM$1000
Jin Teck.. how are you going to truck the gearbox, shaft and entails over to JB? How to tow car to JB should car breakdown after conversion? These are some other consideration on top of direct price consideration.
SWT, you can use the manual trans of the 316, just make sure that it comes with all other necessary stuff like pedal sets, differential etc etc. The wksp doing the conversion should also be well versed with the control system and remember to fully disable the auto-trans module from your ECU. Also prior to work commencement, check, if not replace the seals where applicable.
It is also advisable to perform a full alignment after the work is completed. It's something that I'll do if major components of the undercarriage is changed.
Manual Trans Rockz !!
cheers! looks like i need to get in touch with the seller direclty to find out what's available and what's not.
now we know who is the GURU for e36 : Chairman Jaws
seller said contains everything except rear diff which i can use back my own...but the stuff is now reserved...not sure what it means...
SWT, you still need to get a differential.. yours auto (4.46 if I remember correctly) the ratio is different from the manual.
Ooops, is not pluck n play any more. Never know conversion is so difficult. Jaws, if SWT change to a 318 manual, does that mean that he don't need to change the differential ?
m and q said a change with all materials included will set me back by 3k.
i reckon with a this gear box - 800 plus 1000 labor and the differential..maybe better to go thrug mr chia directly.
go for manual n short shift. it is my best mod so far
where did u get it done and how much did it cost u?
my car original is manual lah. So just change to short shift. Cheap cheap, less then $200.
