Screeching sound after changing brake pads at Performance and was told by them need to change brake discs.
Any recommendation where to get new discs? Is Performance motor warranty still valid if discs changed at other workshops ?
If you want to get your own and DIY, you can get the parts from selected site sponsors as well and watch youtube how to DIY.
I doubt warranty will be valid (related to wheels, brakes etc) if you change outside. Pads I understand is a consumable item but brake disc/rotor?? It should last much longer than the brake pads. Since your warranty is still valid, you should be able to fight your case as to why the brake disc ( I assume its brake rotor) wear out so fast and get them to replace FOC!
