2012 F10 520i Super loud engine noise with video - Please help!
greengas
New Member
Hi guys,
Have a 2012 F10 520i, ~49k km clocked. Recently noticed that the engine is running super loud. Read another thread in this section and seems like a number of 2012 520is are having this problem as well.
I popped the hood after a cold start and the radiator cooling fan is going at full speed. It is damn loud, and the noise sounds like a motor bike. Video below.
https://youtu.be/tIXK7cp9rWk
After driving for about 20 mins, oil temp ~100C. Popped the hood and recorded the noise again. Video below.
https://youtu.be/lNy7-uhiBlY
Both videos show the car on P and in idle. Any opinions on what the heck is going on? Faulty thermostat? Water pump? Clogged pipes? Radiator going kaput? Or is this perfectly normal and I am overreacting?
Gonna bring it to a WS to get it checked out but don't wanna kena chop. Seems like others have changed multiple parts but still end up with this noise after a few months.
Thanks in advance!
Re: 2012 F10 520i Super loud engine noise with video - Please help!
same thing happened to mine…they replaced the thermostat. Problem solved since then. Its either the thermostat or the water pump.
Temp of 100-110 is normal for bmw.
Was it like this when you just got the car ?
Likely thermostat issue like BMWFOREVER said.
Thank you! How much did it cost you?
Thank you! Will get it checked out.
aw8affco
