156F1
Hi, I would like to seek advice from rim and tyre gurus here.
I just fitted 19" rims (8.5J front, 9.5J rear) with tyre sizes 245/35 front and 275/30 rear (recommended by Leong Seng). Compared with 17" stock wheel, the overall radius (D) and circumference (C) are as follows:
Stock 17" 225/50
D = 328.4mm
C = 2,063.4mm
19" 245/35 Front
D = 327.1mm
C = 2,054.9mm
19" 275/30 Rear
D = 323.8mm
C = 2,034.5mm
The 245/35 front and 275/30 rear sizes are also used on BMW OEM 19" rims (except for the M5). Question is that why the rear wheel circumference is smaller than the front, thought rear should be same or larger? Also, would 285/30 (D = 326.8mm, C = 2,053.3mm) be a better fit compared to the stock 17" wheel? Or should the front be 235/35 (D = 323.6mm, C = 2,032.9mm)?
BTW, what tyre pressure should I pump? Same pressure for front and rear, or front lower as stated on the label at the driver door?
Grateful for your advice, cheers!
Stock 17" 225/50
D = 328.4mm
C = 2,063.4mm
19" 245/35 Front
D = 327.1mm
C = 2,054.9mm
19" 275/30 Rear
D = 323.8mm
C = 2,034.5mm
