19" BMW MAHOM staggered 255/35/19 235/35/19
jackshen84
Hi senior, can you guys advise me on this. i just had it installed since a bad PH for 2 X stocks bridgestone 16' tyre puncture. Does it really matter if it a recon set? any idea what is the weigh of this rim? I've tried searching online but only shown Mahom MH01 - Product Wheels - Velg Mobil Racing & Ban Indonesia - Permaisuri.com
First time putting a 19" onto my car. too much?? How much Kpa u guys bump into for a 19 staggered?
I admit i got it impulsively, adding on Michelin pilot super tyre for the rear back.
thank you very much.
Re: 19" BMW MAHOM staggered 255/35/19 235/35/19
As for tire pressure, there should be a sticker on driver's side with door opened to show recommended tire pressure for your car. See if they have recommendation for 19" rims. Probably don't have for 19" judging from size of your rotors but check anyway.
I'll check it out. if i remember vivdly, it does show till 18'. what is your advise for 19' then. thanks.
Sorry not good enough to give advice... I just follow recommendation printed on driver's side and add 1-2 bars coz usually my tires will be warmed up by time reach nearest petrol station to pump tires.
Dear TS,
From Leong Seng Tyres Daniel, Mahom is a replica of Vossen rims. Mahom is made in China, not forged and weighs around 13kg. Vossen rims are forged, made in USA and weighs 9kg max for 19 inches. Replica rims warps easily so its possible that your recon rims have parts that are repaired by hammering the warp part into shape. The repaired portion will naturally be weaker and will easily warp again.
A brand new set from Leong Seng Tyres for Mahom 19 inches cost $800. I hoped you got a good deal.
dannykoo13;1042366 said:
Dear TS,
Thank you for the reply. After seeing your reply, my heart sunken. I got it all in for 1.1k
Next time I shall patronize u guys. Sorry am noob over here. Just found out it made in Taiwan. Nvm, since it alrdy installed. Just ado with it ba.
Look beri conti.....huat arh
2 x 19" PSS should be already $800
1.1 should b a ok price.
Midnight1987;1042158 said:
back 250
front 230
on 19" too
shouldn't the front with the engine have higher air pressure than the rear?
77locorg
