Re: 135 M Sport suspension on E90 possible?
Suspension design is the same as the e90 but as your vehicle weights are different, the ride height can be totally different. Take for examople the e46. int, Case in po The 318 and 320 front springs are different but the rears are the same. So for the 135, there is a shorter and tougher spring in front to lower the car and support the 6cyl engine. At the rear, the 1 series (almost hatch back) should be lighter than the e90 sedan. So again the weights are different. Thus the ride heights cannot be determined. The only way is to swap and try. Uness you can get the exact corner weight of the car.
